Garmin receives approval for the GFC 600 autopilot in Various Aircraft Models
Garmin receives approval for the GFC 600 autopilot in the Baron 58 and Cessna 340 aircraft models
Dateline:
Olathe, KS
Email
PDF
Print
RSS
April 26, 2018 - Garmin is pleased to announce it has received Federal Aviation Administration (FAA) Supplemental Type Certification (STC) for the GFC 600 autopilot for the Baron 58/58A (1984 model year or later) and Cessna 340/340A aircraft. Intended for high performance piston single/twin-engine and turbine aircraft that have a wide range of speed and performance capabilities, the GFC 600 delivers superior in-flight characteristics, self-monitoring technologies and minimal maintenance needs when compared to older generation autopilot systems.
The GFC 600 is designed as a standalone autopilot that boasts superior integration potential with the G500 TXi/G600 TXi and the G500/G600 glass flight displays, Garmin navigators, as well as a variety of third-party flight displays, instruments and navigation sources. The self-contained autopilot controller incorporates backlit keys and a bright, sunlight readable display that depicts autopilot status and mode selection. An intuitive built-in control wheel also provides convenient adjustment of aircraft pitch, airspeed and vertical speed modes. When the level button is selected, the aircraft automatically returns to straight-and-level flight. Environmentally hardened autopilot servos designed for harsh operating conditions contain brushless DC motors and a gear train that eliminates the need for a mechanical slip clutch, offering improved performance and reducing maintenance requirements when compared to decades-old servo designs on the market today. Standard mark-width design of the GFC 600 ensures the autopilot controller allows for routine installation into the aircraft’s avionics stack. Autopilot mode annunciation is available on the G500 TXi, G600 TXi touchscreen glass flight displays, as well as the G500 and G600. The addition of an optional autopilot annunciator panel also displays the selected autopilot mode in the pilot’s primary field of view and retains an identical footprint of third-party autopilot annunciators on the market.
In addition to traditional autopilot capabilities such as altitude hold, vertical speed and heading modes, the GFC 600 also includes:
Premium functions and advanced capabilities such as altitude pre-select1 and indicated airspeed hold mode. VNAV will be a growth function when appropriately equipped.
Pilots can select, couple and fly various instrument approaches, including GPS, ILS, VOR, LOC and back course approaches2.
Built-in GPS roll steering capability eliminates the need for external roll steering converters, allowing for smoother navigation tracking when installed with a compatible navigator.
Level Mode button, which automatically engages the autopilot to restore the aircraft to straight and level flight.
Underspeed protection helps prevent the pilot from stalling the aircraft.
Overspeed protection helps prevent the pilot from exceeding aircraft maximum speed (VNE).
With the addition of an optional yaw servo, Yaw Damper (YD) mode minimizes yawing oscillations while also helping to maintain coordinated flight by keeping the slip/skid indicator centered.
Flight Director command bars can be displayed on a variety of flight displays, such as the G500 TXi/G600 TXi and select third-party flight displays.
Pilots can fly coupled ‘go-arounds’ during missed approach sequencing. A remotely-installed go-around button commands the Flight Director to display the appropriate pitch attitude required for the missed approach procedure and activates a loaded missed approach when paired with a GTN 650/750 navigator.
An optional pitch-trim servo adds automatic trim and manual electric trim.
Control wheel steering is available, which allows the pilot to adjust pitch, roll, altitude hold, vertical speed or airspeed references using the control yoke while the autopilot is engaged.
As a standard feature, pilots receive Garmin ESP with the GFC 600 autopilot, which works to assist the pilot in maintaining the aircraft in a stable flight condition. ESP functions independently of the autopilot and works in the background to help pilots avoid inadvertent flight attitudes or bank angles and provide airspeed protection while the pilot is hand-flying the aircraft.
Garmin also expects to further expand its list of aircraft models approved for the GFC 600 autopilot. Upcoming aircraft models include:
Beechcraft Baron 58/58TC/58P (1983 model year or earlier)
Cessna 208B
Cessna 414A
Cessna 421C
Piper PA-46 (310P, 350P*)
TBM 700A/B/C1/C2/N (TBM 850)
The GFC 600 autopilot has received FAA STC in the Baron 58/58A (1984 model year or later) and the Cessna 340/340A and is available for a suggested retail price starting at $23,995 and $22,995 respectively for a 2-axis autopilot with electric trim. Visit Garmin.com/GFC600Aircraft to view the most up-to-date information regarding current and future certification programs for the GFC 600 autopilot. To express interest for the certification of either the GFC 600 or GFC 500 autopilot in additional aircraft types, contact aviation.sales@garmin.com and provide specific aircraft make/model information. For additional information, visit: www.garmin.com/aviation.
1. Available on Garmin flight displays.
2. GFC 600 requires an external navigator for navigation and approach functions.
*Jet Prop not included in initial certification
Dateline:
Olathe, KS
RSS
Cessna 208B
Cessna 414A
Cessna 421C
