PTT Problem
in Avionics
I am member of Cessna Owner Organization and i am A&p responsible for the maintenence of our airplanes. We have a 1978 172n 17269979 and a issue with the ptt.
The plane has the Collins 251 vhf with the arc 300 audio panel.
The speaker is directly wired to com 1. No matter what you select on the audio panel. The speaker is in the position.
Intermittently the ptt stops working. I replaced the ptt and checked the wires on the back side of the instrument panel but no luck. I replaced the audio panel and the speaker is still directly wired com 1.
When the ptt stops working the mic also does not work. However the velcro ptt on the passanger side will transmit (we have a 2 place external intercom box with a spare ptt for the co-pilot and hardwired ptt on the pilot side).
Do you have the cessna electronics manual with the Collins arc.300 wire schematic. I cannot find a good copy and cessna wants $300 for a copy of the manual.
I have taken the airplane to Rochelle Avionics and Rockford avionics and they will not repair the arc audio panel. They want to install a new audio panel and intercom for 3k
We are going to install a 4 place intercom this winter but need to figure out what is causing out ptt issue.
One forum said the audio amplifier could cause this issue. Where is the amp. I know where the radio 24-12v transformer are but cannot find a speaker amp.
Please advise
Please advise
You mentioned you are an A&P if that's correct it is legal for you to install a used audio panel off eBay or wherever at a price point less than $3,000.
You asked about a schematic, do you mean a pin out for the connector? If so a copy of "quick shots" available from Edmo is probably a great addition to your toolbox, it has pin outs for hundreds of popular legacy boxes in it.
There is probably not a remote speaker amp anywhere, its likely in com 1 and not wired correctly.
Calling a shop and asking for prints is not a sin, all they can do is say no, and you call another one...
Just the view from my hangar~
~Erich Rempert, A&P Consultant
​​​​​​​Bob Hart www.AvionixHelp.com
We found our Ptt problem. The coiled wire under the yoke and a short from the yoke map light to the ptt circuit.
Same 172n 1977 with the Collins 251 radios. Why does the audio panel not shut off the overhead speaker. Do you have a electrical schematic of the ARC 300 audio panel(0570115-6-28)? We tried two different panel and the overhead speaker is always on. I have found schematics for the maker beacon but not the audio panel portion
Tony Zurek
