CHT temperature
My plane has 0470M engines with the Bendix PSD-5C pressure carbs. I only have a single thermistor probe cylinder 3 each engine. While both engine indications of EGT and CHT have matched after start climb cruise the left engine CHT temperature still matches until I lean in cruise. At that point the CHT drops to about 225 . If I push its mixture control to full rich it then mirrors the right . The thermistor probe checks good and gauge has been overhauled. Any ideas what could be causing this change in cruise?
    I will send this to our A&P, Erich Rempert for his comments. Please stand by.
    Here are comments from Erich:
    The only thing I can think of is #3 cylinder on the Left engine has an induction leak and is running leaner than the others when you reduce power. (So lean; the temp falls off because it's not making power anymore).
    What happens to the EGT?
    Go over all the induction clamps and couplings closely. Also possibly look for a broken primer line to #3 cylinder.
    Since things match up at full power/full rich and present after leaning for cruise it sounds like an induction leak based on what you've given me.
    [Induction/Vacuum leaks become more apparent at lower manifold pressures, at full throttle their effects virtually disappear because the manifold pressure is almost the same as atmospheric.]
    An engine monitor would give us a much larger picture of what's happening and be very helpful in this instance. As of now we don't know if this is a problem effecting one cylinder or the whole engine.
    You also didn't mention if the EGT probe is also on #3, if it isn't, it's indications are of little value when diagnosing this issue.
