FAA AD on United Altimeters manufactured in 2015 and 2016
1
[Federal Register Volume 82, Number 41 (Friday, March 3, 2017)]
[Rules and Regulations]
[Pages 12395-12397]
From the Federal Register Online via the Government Publishing Office [www.gpo.gov]
[FR Doc No: 2017-03488]
DEPARTMENT OF TRANSPORTATION
Federal Aviation Administration
14 CFR Part 39
[Docket No. FAA-2016-9345; Directorate Identifier 2016-CE-028-AD; Amendment 39-18801; AD 2017-04-06]
RIN 2120-AA64
Airworthiness Directives; United Instruments, Inc. Series Altimeters
AGENCY: Federal Aviation Administration (FAA), DOT.
ACTION: Final rule.
SUMMARY: We are adopting a new airworthiness directive (AD) for certain United Instruments, Inc. 5934 series altimeters that were manufactured between January 2015 and February 2016 and installed in airplanes and helicopters. This AD was prompted by reports of certain altimeters displaying higher than actual altitude due to a slow diaphragm leak, which would affect the accuracy of the altimeters. This AD requires replacing the affected altimeters. We are issuing this AD to correct the unsafe condition on these products.
DATES: This AD is effective April 7, 2017.
The Director of the Federal Register approved the incorporation by reference of a certain publication listed in this AD as of April 7, 2017.
ADDRESSES: For service information identified in this final rule, contact United Instruments, Inc., 3625 Comotara Avenue, Wichita, KS 67226; telephone (316) 636-9203; fax: (316) 636-9243; email: customerservice@unitedinst.com; Internet: www.unitedinst.com or http://www.unitedinst.com/Products/SpecificationsSheets/d132811.aspx. You may view this referenced service information at the FAA, Small Airplane Directorate, 901 Locust, Kansas City, Missouri 64106. For information on the availability of this material at the FAA, call (816) 329-4148. It is also available on the internet at http://www.regulations.gov by searching for and locating Docket No. FAA-2016-9345.
Examining the AD Docket
You may examine the AD docket on the Internet at http://www.regulations.gov by searching for and locating Docket No. FAA-2016-9345; or in person at the Docket Management Facility between 9 a.m. and 5 p.m., Monday through Friday, except Federal holidays. The AD docket contains this AD,
2
the regulatory evaluation, any comments received, and other information. The address for the Docket
Office (phone: (800) 647-5527) is Document Management Facility, U.S. Department of
Transportation, Docket Operations, M-30, West Building Ground Floor, Room W12-140, 1200 New
Jersey Avenue SE., Washington, DC 20590.
FOR FURTHER INFORMATION CONTACT: Les Lyne, Aerospace Engineer, FAA, Wichita
Aircraft Certification Office, 1801 Airport Road, Room 100, Wichita, Kansas 67209; telephone:
(316) 946-4190; fax: (316) 946-4107; email: leslie.lyne@faa.gov.
SUPPLEMENTARY INFORMATION:
Discussion
We issued a notice of proposed rulemaking (NPRM) to amend 14 CFR part 39 by adding an AD
that would apply to certain United Instruments, Inc. 5934 series altimeters that were manufactured
between January 2015 and February 2016 and installed in airplanes and helicopters. The NPRM
published in the Federal Register on November 7, 2016 (81 FR 78083). The NPRM was prompted by
a report that certain 5934 series altimeters that were manufactured between January 2015 and
February 2016 may display higher than actual altitude. These altimeters are susceptible to developing
a slow diaphragm leak, which would affect the accuracy of the altimeters. It has been determined that
insufficient removal of chemical substance on the diaphragm assembly during the production process
of the altimeter caused the misleading display of altitude data. The NPRM proposed to require
replacing the affected altimeters. We are issuing this AD to prevent display of misleading altitude
data, which could result in inadvertent flight into terrain.
We gave the public the opportunity to participate in developing this AD. We received no
comments on the NPRM or on the determination of the cost to the public.
Conclusion
We reviewed the relevant data and determined that air safety and the public interest require
adopting this AD as proposed except for minor editorial changes. We have determined that these
minor changes:
ï‚· Are consistent with the intent that was proposed in the NPRM for correcting the unsafe
condition; and
ï‚· Do not add any additional burden upon the public than was already proposed in the NPRM.
Related Service Information Under 1 CFR Part 51
We reviewed United Instruments, Inc. Service Bulletin No. 13, dated March 25, 2016. The
service bulletin describes procedures for replacing the nonconforming altimeters. This service
information is reasonably available because the interested parties have access to it through their
normal course of business or by the means identified in the ADDRESSES section.
Costs of Compliance
We estimate that this AD affects 1,351 altimeters as installed in airplanes and helicopters of U.S.
registry.
We estimate the following costs to comply with this AD:
3
Estimated Costs
Action Labor cost Parts
cost
Cost per
product
Cost on U.S.
operators
Replace
altimeter
1 work-hour × $85 per hour
= $85
$1,600 $1,685 $2,276,435
According to the manufacturer, some of the costs of this AD may be covered under warranty,
thereby reducing the cost impact on affected individuals. We do not control warranty coverage for
affected individuals. As a result, we have included all costs in our cost estimate.
Authority for This Rulemaking
Title 49 of the United States Code specifies the FAA's authority to issue rules on aviation safety.
Subtitle I, section 106, describes the authority of the FAA Administrator. Subtitle VII: Aviation
Programs, describes in more detail the scope of the Agency's authority.
We are issuing this rulemaking under the authority described in Subtitle VII, Part A, Subpart III,
section 44701: “General requirements.” Under that section, Congress charges the FAA with
promoting safe flight of civil aircraft in air commerce by prescribing regulations for practices,
methods, and procedures the Administrator finds necessary for safety in air commerce. This
regulation is within the scope of that authority because it addresses an unsafe condition that is likely
to exist or develop on products identified in this rulemaking action.
Regulatory Findings
This AD will not have federalism implications under Executive Order 13132. This AD will not
have a substantial direct effect on the States, on the relationship between the national government and
the States, or on the distribution of power and responsibilities among the various levels of
government.
For the reasons discussed above, I certify that this AD:
(1) Is not a “significant regulatory action” under Executive Order 12866,
(2) Is not a “significant rule” under DOT Regulatory Policies and Procedures (44 FR 11034,
February 26, 1979),
(3) Will not affect intrastate aviation in Alaska, and
(4) Will not have a significant economic impact, positive or negative, on a substantial number of
small entities under the criteria of the Regulatory Flexibility Act.
List of Subjects in 14 CFR Part 39
Air transportation, Aircraft, Aviation safety, Incorporation by reference, Safety.
Adoption of the Amendment
Accordingly, under the authority delegated to me by the Administrator, the FAA amends 14 CFR
part 39 as follows:
PART 39–AIRWORTHINESS DIRECTIVES
1. The authority citation for part 39 continues to read as follows:
Authority: 49 U.S.C. 106(g), 40113, 44701.
4
§ 39.13 [Amended]
2. The FAA amends § 39.13 by adding the following new airworthiness directive (AD):
5
FAA
Aviation Safety
www.faa.gov/aircraft/safety/alerts/
www.gpoaccess.gov/fr/advanced.html
2017-04-06 United Instruments, Inc.: Amendment 39-18801; Docket No. FAA-2016-9345;
Directorate Identifier 2016-CE-028-AD.
(a) Effective Date
(b) Affected ADs
None.
(c) Applicability
This AD applies to United Instruments, Inc. 5934 series altimeters that were manufactured
(1) The specific affected serial number altimeters can be found in United Instruments, Inc.
Service Bulletin No. 13, dated March 25, 2016. Paragraph (j)(3) of this AD contains addresses for
obtaining the service bulletin.
(2) Altimeters that have been corrected by United Instruments, Inc. following Service Bulletin
No. 13, dated March 25, 2016, are not affected by this AD and no further action is necessary.
(3) Altimeters that have been corrected by United Instruments, Inc. can be identified by a yellow
dot, approximately 1/4 inch (6 mm) in diameter, located approximately 1 inch (25 mm) to the left
side of the nameplate. The corrected altimeters will also have a letter “M,” approximately 1/8 inch
(3mm) high, metal stamped on the nameplate after the name “ALTIMETER.”
(d) Subject
Joint Aircraft System Component (JASC)/Air Transport Association (ATA) of America Code
44, Cabin Systems.
(e) Unsafe Condition
to a slow diaphragm leak. We are issuing this AD to prevent display of misleading altitude data,
(f) Compliance
Comply with this AD within the compliance times specified, unless already done.
(g) Replacement
Within the next 12 months after April 7, 2017 (the effective date of this AD), replace any
affected altimeter with a serviceable part following United Instruments, Inc. Service Bulletin No. 13,
6
(h) Alternative Methods of Compliance (AMOCs)
(1) The Manager, Wichita Aircraft Certification Office (ACO), FAA, has the authority to
approve AMOCs for this AD, if requested using the procedures found in 14 CFR 39.19. In
accordance with 14 CFR 39.19, send your request to your principal inspector or local Flight
Standards District Office, as appropriate. If sending information directly to the manager of the ACO,
send it to the attention of the person identified in paragraph (i) of this AD.
(2) Before using any approved AMOC, notify your appropriate principal inspector, or lacking a
principal inspector, the manager of the local flight standards district office/certificate holding district
office.
(i) Related Information
For more information about this AD, contact Les Lyne, Aerospace Engineer, FAA, Wichita
ACO, 1801 Airport Road, Room 100, Wichita, Kansas 67209; telephone: (316) 946-4190; fax: (316)
(j) Material Incorporated by Reference
(1) The Director of the Federal Register approved the incorporation by reference (IBR) of the
service information listed in this paragraph under 5 U.S.C. 552(a) and 1 CFR part 51.
(2) You must use this service information as applicable to do the actions required by this AD,
unless this AD specifies otherwise.
(i) United Instruments, Inc. Service Bulletin No. 13, dated March 25, 2016.
(ii) Reserved.
(3) For United Instruments, Inc. service information identified in this AD, contact United
(4) You may view this service information at FAA, Small Airplane Directorate, 901 Locust,
(5) You may view this service information that is incorporated by reference at the National
Archives and Records Administration (NARA). For information on the availability of this material at
NARA, call 202-741-6030, or go to: http://www.archives.gov/federal-register/cfr/ibr-locations.html.
Issued in Kansas City, Missouri, on February 6, 2017.
Kelly A. Broadway,
Acting Manager, Small Airplane Directorate,
Aircraft Certification Service.
