Stratus ESG Malfunction
in Avionics
I took the plane out for a spin this weekend and encountered my first problem with my Stratus ESG transponder that we installed in January of 2017. I noticed when I first took off that the accuracy shown on my iPad was 23 meters. After a while this eventually improved to 10 meters then to 5. This may just be separate event. The real problem came when I went to press the function key to view my pressure altitude. After pressing it, nothing happened. I then pressed one of the numbered keys and once again nothing happened until I pressed them multiple times. After finally getting a response I ended up with a random code entered. I was VFR so I clicked the VFR button and once again nothing. I pressed standby and it went into standby. From here I pressed VFR again and ended up with a 5 being entered into the code. Every time I pressed VFR another 5 would be entered in the box until I ended up with “5555.†At this point I powered down the Stratus and pull the breaker for a 10 minute time-out. I then pushed the breaker and turned it back on. Once again only the power button worked with none of the other buttons functioning correctly. I emailed Appareo and hope to hear from them tomorrow. I will keep this post updated for those who installed the Stratus ESG so they know what to look for if something similar happens them. It seems to me that it’s just a keyboard malfunction because when it is on it acquires a GPS signal, switches from ground to air, and indicated the reply signal. Right now I just can’t use anything other than “1200.â€
http://www.radioranchinc.com/
When it happens with a new product like this, we learn what kind of company we are dealing with. It looks like Appareo passed the test! Thanks!
Bob Hart www.AvionixHelp.com
Help! Has anyone else had their Stratus ESG feed back through their comm system? On my second shop now and after thousands of $ I'm told by Stratus "they are aware of the problem" but has no fix.
Hi, you need too talk to Stratus directly. Give them a call tomorrow.
