C182P turned Peterson 260SE
Continental IO-470F & Canard STCs from Peterson Performance
Ballistic Recovery Systems (BRS) whole airplane parachute system (STC by BRS) behind back seat
Chelton panel with Electronic Int'l engine analyzer
Flaps stall 35kts
Clean stall 38kts
14" / 60kts downwind through final
Wow! What are the performance specs?
Right, Kent. Wow! What a beautiful airplane!
Read a little on the Chelton systems. VERY highly regarded...may be superior to Garmin or Avidyne...very costly..
Thanks Kent. Here is a link to a 2007 Plane & Pilot article that gives specs for a very comparable aircraft... however my fuel cap is lower (74 gal) and my useful load is a bit lower due to extensive panel and interior. Notably, the BRS parachute system comes with a gross weight increase STC, so the NET result is about 65lb INCREASE in useful load (see the second link below).
https://www.planeandpilotmag.com/article/peterson-260se-n735gh-2/#.XH1zzdF7kUE
http://www.flyingmag.com/aircraft/m...-load-increase-cessna-182#3FuVF0OCK8gj8y1L.99
Hi, just letting you know that the link above produced a "page not found".
The Plane and Pilot link worked for me, not the FlyingMag though...
Thanks Commish. Incredible what can be accomplished! With proper funding...lol
I can see the speed vs fuel burn is VERY favorable!
