Seat Back Bolts SAIB
We led the email newsletter with this but just making sure everybody saw this.
https://cessnaowner.org/saib-issued-check-your-seat-back-bolts/
The FAA has issued a Special Airworthiness Information Bulletin for numerous Cessna models to alert owners and operators that they should inspect the bolts that attach to the seat base of the pilot and copilot seats.
The SAIB says you should check this if your seat part numbers are:
0515001-20, -25, -26, -208, -209, -210, or -211.
There will not be an AD issued for this situation, the SAIB states. The recommendation is to perform a repetitive 200-hour visual inspection of the bolts that attach the seat back to the seat base of the pilot and copilot seats.
also attaching the PDF here.
Digital Product Manager
Cessna Owner Organization
Thanks Rocky!
