Uneven fuel flow question
I know this is a dead horse. I am aware Cessna highwing aircraft are famous for flowing more fuel from one tank than the other. I have read about the position of the vent wing. Before I start experimenting with raising or lowering that vent slightly, can anyone advise if it should go up further into the wing or down and extended slightly in order to reduce the flow from the right tank to balance the flow with the fuel selector in the both position. I have to fly with a fuel selector on the left for one hour and both for one hour and then alternate in order to keep the level in the tanks within a few gallons of each other. If I leave it on both it wants to essentially drains the right tank. I am flying in trim. I’m not hearing pressurization when I open the fuel caps.
The April issue has a long discussion about this in it
https://cessnaowner.org/apr22/
and then separately from that, the story above actually came from this discussion:
https://forums.cessnaowner.org/discussion/comment/4482#Comment_4482
good luck!
Digital Product Manager
Cessna Owner Organization
Thanks sir! I may need to evaluate the vents again. Although the flow is not even at present, I at least know what to expect and how to manage. After climb and level off, I fly left tank x 1 hour then both and alternate. I am within about 5 gallons at the end of a 2.5-3 hour flight. I appreciate all of the comments. and advice.
