1969 Cessna 337 Flight Manual
Trying to get a new empty weight for a 337-D Super Skymaster. Is there a specific Flight Manual to resource for the needed information? I have the Owners Manual, but very little info on how to level a/c for accurate calculations. Any help appreciated.
The Type Certificate Data Sheet, current POH for your specific serial number aircraft, current Weight and Balance data, and the Service Manual for your aircraft will have all of the pertinent information to complete the task. The work to update the weight and balance must, as you know, be done (or supervised) by an A&P/IA as it is not considered preventive maintenance.
Thank you Mike!
Mike,
Where/how can I get a copy of the ATCDS for the 337-D. Logs were lost and cannot locate original. I have the POH, Weight/Balance calc and service manual. Need to do new W/B calculation and A&P needs the data sheet to complete. Any help appreciated.
