Mixture control 177B or any 177
Can anyone post a photo of the mixture control attach bracket and routing in a Cessna 177B or any 177. Helping a friend with his mixture cable and I want to make sure it attached properly. IPC is no help. Posting a photo from another forum. Looking for a better photo of the attach bracket. Thank you
    edited June 2025
    I see there are no member replies to this topic, so let me offer this...
    The best person to confirm the control cable is routed properly is the A&P/IA who will perform the work (or supervise the work being performed) and who is required to fill out the necessary paperwork, sign the logbook, and return the aircraft to service.
    • Michael Jay Jones (MikeJJ),
  • jcar,
    I had a similar question regarding the correct placement of the throttle cable support bracket on my 172. (it turned out that the bracket had been installed incorrectly)
    I contacted Cessna technical support at:
    Piston_Support@txtav.com
    and got the information I needed including a detailed engineering drawing showing the bracket installation. They should be able to provide the information that you need.
    Tom
