GTX335 vs. Appareo ESG
New member here. Bought my first airplane this spring! 1976 Cessna 172M. Has steam gauges and 2 new TKM Nav/Coms . VFR pilot currently using I-Pad with Garmin Pilot. Have reserved my rebate and ready to pull the trigger on a new ADSB out solution. Have decided on ADS-B out only. I would really appreciate any feedback/advice on which unit to go with. Once installed, will I notice any difference between the two? Does the "Bluetooth" vs. Wi-Fi make a difference in the cockpit? Thanks in advance for your thoughts! Mike M.
Cessna Owners Organization
Good luck.
