Seattle area Cessna Cardinal mechanic
I live a bit north of Seattle. I recently bought my first airplane and I'm looking for a good shop. I bought it in California and used a local shop to pre-buy. It's a 1972 Cessna Cardinal 177RG. The plane is in good condition overall. It flies terrific, but I have six things I want to address. 1) I'm not able to fly at night right now because my nav lights aren't working. When I turn on the nav lights, the beacon breaker pops. 2) While my primary Nav/Comm is really solid, my secondary is pretty poor--perhaps antenna, wiring, the radio itself, resonance noise from the panel... 3) The engine has pretty good compression but still seems a bit anemic, both on takeoff and at cruise. 4) I want to add shoulder harnesses for the front. 5) I lack push-to-talk for the co-pilot. 6) My doors may need to have the hinges or the latching mechanisms adjusted because they can be a bear to close. A bit of work overall for an otherwise solid plane. Any recommendations on a shop between Seattle and Bellingham that would be really strong with older Cessnas?
289 E. Perimeter Rd
Renton, WA 98057
Toll Free 1-888-734-4223
Phone – 425-204-084
I would have preferred one with a 60 gallon tank and a fuel selector valve for right/left instead of on/off. The later models had those but the 71/72 didn't. I've looked around for a mod that would give me the extra 10 gallons but there doesn't appear to be an STC for the Cardinal. I lose an hour of duration, and when I'm flying by hand I have to be a bit more active with the roll because it tends to drain one take before the other. However, I have the S-TEC 50 with GPSS. It rolls the plane flat as anything and does a great job steering a heading. It's altitude hold isn't so great but what fun would it be if I didn't have to interact at least a little bit with the controls?
