Over head air duct noise
I just bought his T210N in January and didn’t really need to use the the ceiling air ducts much because it was cold and we needed heat. Now that is super hot I need all the air we can get in the cabin. Turning the ceiling air on full is really noisy especially since it is right buy my ears. Closing it part of the way reduces the noise but of course reduces the air flow. It’s like something in the duct vibrating making this irritating noise not just a air flow noise. Does everyone have this same problem? Anyone find a solution?
I went with the Wilco STC for nozzle type air vents. work great and greatly increased airflow and directional control. Very positive off position for cold days. Only draw back is taking the headliner down and a fair bit of minor trimming to mount them. While you are at it, replace all the old ducting too! The old black paper ducting is probably so full of dirt it will scare you!
Drdoogie1, can you give me a little more details on the netting at the intake. There is a fixed metal grill on the intake but is fixed and solid from any vibration
Thanks, Jerry
Excellent! Good to know
My 206 had metal mesh in the intake but this 210 just has a fixed metal grill. I actually tried adding metal mesh but I still had the noise with a lot less air flow. I think replacing the ducts would be a good start and it might reveal something. Thanks everyone
Does anyone know where I can get rear air vents for a Cessna 182Q models OEM or nozzle type?
We're going to need a part number to find it for you.
