Camber light wing with bonded leading edge
edited January 17 in General Discussion
What is bonded leading edge mean? Did Cessna use a filler to smooth out the leading edge where the skins met by the forward spar. Asking about 185's
  • planewrenchplanewrench IA 46yr A&P DAL A/C Inspector
    edited January 17
    Simple explain is bonded is glued. I think the STC's call out for light pop rivits as well as "bonding/ glue " along the length of the leading edge. Its not coming off if that is what you;re thinking.
    If someone has had it done recently, chime in.
  • Thank you. Carl
