Rear Window Replacement- seal
R172K - What type of sealant do you use with the felt in replacing the rear window.
Does anyone know a replacement for the No. 579-6 Inmont Corp., sealant that the manual is talking about.
As to the editorial content of the April edition, I have an A&P review and sign off my work.
These people should know!
Aircraft Window Repairs
FAA/CRS # XK3R974L / EASA.145.4359
FAA Diamond Award Certificate of Excellence Recipient
2207 Border Avenue
Torrance, CA 90501
Ph: 310-212-7173
Fax: 310-212-0905
info@awrepairs.com
What I use for window sealing Coffee.
Rear windows take more heat than the sides. Avoid the temptation to use the clear RTV from Home Depot; won't last like this will.
Steve
