2001 Cessna 182T Beacon
Hello All! I went to change my beacon bulb and was surprised to find something that is not listed in my Illustrated Parts Manual. It lists two options depending on serial number but neither of them are what I have. I tried to google the part numbers on it and got no significant returns. See pictures. Does anyone know where this came from. I was able to get the bulb.
I have a 2001 T182T and that looks similar to the one I had. However, yours looks like it could be an aftermarket of some sort.
With mine, the bulb was good but the electronics to enable flashing was bad. I replaced mine with Textron recommended Wheelen 71560 LED (Textron 01-0771560-00) assembly. It was a plug and play.
If your 182T is SN #80945 or higher, your part number should have been 01-077086-01, just like mine.
