flysto.net flight data analysis for Cessnas
FlySto.net is an amazing (and free) online tool that helps pilots review and analyze their flight data. It supports track logs from ForeFlight, Garmin Pilot, most onboard avionics, and even ADS-B. By uploading your flight log, you can visualize key performance metrics, track trends, and gain insights to improve safety and efficiency.
Keep in mind you'll get more out of it if you send higher quality flight logs like those from avionics with EIS info.
FlySto is preconfigured for a range of Cessna models, including:
Cessna 152
Cessna 172M
Cessna 172N
Cessna 172R
Cessna 172S
Cessna 177RG
Cessna 182N
Cessna 182P
Cessna 182T
Cessna T206H
Cessna 208B
Cessna 208B-Extended Payload STC
Cessna 208BEX
Cessna 208BEX-Extended Payload STC
Cessna 210 Silver Eagle
Cessna 414A
Cessna 421C
Cessna TTx
If your aircraft isn’t on the list, simply select “Other” and enter some basic data from your POH. New aircraft models are being added regularly (and you can ask them to add yours if you do a little POH/TCDS work first).
No advanced tech knowledge is needed—just upload your flight log and explore your data in a pilot-friendly format.
I have nothing to do with flysto, I've just found it to be an incredible tool and I'm pleased to see that they are adding more CESSNA MODELS.
You can see a demo here: https://www.flysto.net/logs/5qdrds0p?view=2d
Or the overview here: https://www.flysto.net
