SAF-AIR F62 oil quick drain plug
I purchased this for my T210N model but discovered it will not work for a 550 conversion. It is my understanding that it will work for a 210 with a 520, and of course it will also work form most other Continentals. Please do your own research. These are $150 at Aircraft Spruce. I will sell this one for $80, including shipping anywhere in the lower 48. It was installed and then immediately removed when it became obvious that nose gear retraction would be a problem. So, used, but not really. Please contact me at PITTS7RN@yahoo.com.
Leave a Comment
Rich Text Editor. To edit a paragraph's style, hit tab to get to the paragraph menu. From there you will be able to pick one style. Nothing defaults to paragraph. An inline formatting menu will show up when you select text. Hit tab to get into that menu. Some elements, such as rich link embeds, images, loading indicators, and error messages may get inserted into the editor. You may navigate to these using the arrow keys inside of the editor and delete them with the delete or backspace key.
