USB Power Port Replacement for Standard 12v Cigarette Lighter Socket
Guardian Avionics Introduces Dual 2.1 Amp USB Power Port Replacement for Standard 12v Cigarette Lighter Socket for Certified Part 23, 27, and 29 Aircraft & Rotorcraft
January 4, 2017 - FOR IMMEDIATE RELEASE
Tucson, Arizona – Guardian Avionics is excited to introduce a new and simple USB power upgrade option for aircraft owners who have an old 12v cigarette lighter socket in their current panel – the Guardian Avionics Power 250-101R Dual 2.1 Amp USB Power Supply with a 0.9†diameter round faceplate designed to fit a standard round cigarette lighter socket opening in the instrument panel.
Since USB has become a popular standard for powering smartphones and tablets, pilots in certified aircraft have been required to use bulky adapters for their existing 12v lighter socket to gain a usable USB port. The new round USB unit perfectly replaces the lighter socket and adds a clean dual USB port that sits flush with the panel converting any aircraft power source from 9 VDC to 48 VDC down to an output of 5 VDC at 2.1 Amp per USB port. Only two countersunk screws need to be added to mount the new unit and the power supply can be wired to aircraft power through a 2 Amp circuit breaker in place of the existing circuit breaker for the 12v lighter socket.
This round dual USB unit, along with all USB models offered by Guardian Avionics, are listed as part of the Federal Aviation Administration “Non-Required Safety Enhancing Equipment†(NORSEE) letter of authorization issued to Guardian Avionics, meaning that the unit may be installed by an A&P/IA with only a minor alteration logbook entry in any CFR Part 23, 27, or 29 certified aircraft/rotorcraft. No time consuming and costly STC or Form 337 required.
“There are tens of thousands of certified General Aviation currently flying in the United States with a factory installed cigarette lighter in their panel.†noted Ash Vij, President of Guardian Avionics. “More and more of the pilots flying those aircraft are using tablets and phones with apps for navigation and they need reliable and safe USB power to power them in flight. Our simple, affordable, and attractive replacement is a fantastic upgrade for any aircraft owner.â€
The USB unit also features a green LED backlight for easier use in night flying conditions, is EMI shielded to prevent noise in radios, and features reverse polarity protection for added safety. The power supply is also available with a 0.8†custom square faceplate as the Power 250-101S for custom installations in the panel or in the passenger cabin.
Both dual USB units are retail priced at $299.00 and are immediately available at GuardianAvionics.com or through authorized Guardian Avionics dealers and distributors.
About Guardian Avionics
Based in Tucson, Arizona and established in 1999, Guardian Avionics / CO Guardian is a leading provider of Carbon Monoxide detectors, iPad/iPhone panel mounts, USB power supplies, and connected cockpit solutions for General Aviation ranging from portable units to FAA TSO certified models. Guardian Avionics products are featured as standard safety equipment for new aircraft from OEMs including Cessna Aircraft Company, Cirrus Aircraft, Piper Aircraft, Diamond Aircraft Industries, and Beechcraft Corporation. For more information, please visit www.GuardianAvionics.com or contact by phone at 520-889-1177.
MEDIA: High Resolution Images located at: http://www.guav.co/highres/Power-250-101R-Dual-USB-12v-Lighter-Replacement-High-Res.zip
Ryan Keough
Manager of Sales & Marketing
Guardian Avionics
ryan@guardianavionics.com
(520) 889-1177 (Office)
(585) 380-2028 (Mobile)
(520) 889-8249 (Fax)
1951 E. Airport Dr.
Tucson, AZ 85756
http://www.guardianavionics.com
Ryan Keough
Guardian Avionics
1951 E. Airport Dr.
Tucson, AZ 85756
