EPIRB LOCATION 406 BEACON
Scott & members,
Can you please advise me as to the location of my EPIRB (406 beacon) in my 2004 Cessna T206H, so I can procure the epirb id, and update the registration records? I suspect it should be located in the aft end, maybe behind my luggage area.
Best,
Paul
    Hi Paul,
    It's generally easily accessible so try behind the luggage area. Let me know if it's not there and I'll keep looking for you.
  • Thank you Scott, You are right on, I checked on it today, and they placed the TKS ice protection fluid tank there. So I suspect, I will need to remove the tank to get to the ELT, as there is a ELT placard "ELT located behind panel".
    Best,
    Paul
    Fantastico, Paul! :)
