Pre-delivery flight on 1998 182S model.
Hello fellow Cessna owners, I just purchased my first airplane and I couldn't be more excited! With that said, I am going on a demo/pre-delivery flight to make sure all the systems are in working order before I leave with my new bird. Since this will be my first time, I really don't want to overlook anything or miss something that is common knowledge for seasoned airplane owners. Does anyone use a checklist or have a few key items they ask the demo pilot to perform or show on these types of flights? I appreciate any tips or advice!
    Hello Mr. Nichols,
    Thanks for the post. Here are some of the things on do on my first pre-purchase flight of a new airplane (I've owned 8 planes, so far!)
    1. Make sure the plane flies straight and level during cruise.
    2. Make sure the engine is smooth and no roughness. Check both mags.
    3. Make sure the prop will change pitch smoothly.
    4. Make sure the brakes work smoothly.
    5. How close to book speeds and climb performance is it?
    6. Check all avionics thoroughly. Don't forget ELT in tail.
    7. Check all lighting.
    8. Check windows (especially those that open up).
    9. Check door locks
    10. Check seat belts
    Let's see what others add to this list.
  • Hello Nicholas,
    Was there a pre-purchase inspection done on the airplane? Has it had an annual inspection in the last 12 months?
    I would first look in the logbooks to check the above. Checking the logs will tell when/how much it has flown recently. Engine items to check in logs:
    1. When was oil last changed? If more than 6 months I would change it and cut open filter before delivery flight. If the oil is pitch black on the dipstick that further tells you to change it before flight.
    2. While in logs check how many hours are on each mag - if more than 500 they need to be overhauled. # of years since overhaul also matters. If the delivery flight is a long one, consider options for getting stuck. Our delivery flight last year was one start away from leaving us stranded due to bad mag- and our mags had only 65 hrs on a 3 yr old overhaul.
    3. With mags off, I like to pull the prop thru to feel compression on all six cylinders(carefully) with the engine cold. If one feels soft, then get ready to borescope. Does the airplane have an engine monitor? If so watch it closely in flight.
    4. I would remove the top engine cowl side panels so you can make a close visual inspection of the engine before flying. Look for things that are chafing, pull on the exhaust to make sure it is secure and look for any leaks at the cylinder flanges. Use your flashlight to see well. Be sure to have a digital CO monitor for your delivery flight and keep it in your scan.
    5. On a Cessna I've not flown before, I go to the elevator and hold it horizontal/level and move either side up&down pushing to oppose either side. This confirms a sound connection to the torque tube. If you feel differentail movement - don't fly and find a mechanic. I've rejected more than one airplane for flight when finding differential elevator movement.
    6. I like to move the wingtips up & down a bit to feel for any movement in the strut connections in an unfamilar airplane. Do both sides.
    7. Grab the nose gear torque link/scissors and try to move it side to side, and up & down. If there's any movement get ready for shimmy.
    8. With wheel fairings its difficult, but try to get a visual on each tire perimeter looking for worn spots or cord. Any cord showing means replace tire before flight.
    9. Can also check the Service Manual annual inspection item list if you want to delve further on a specific item. Make sure you have a service manual in case you need to refer to it on the delivery flight.
    Your normal preflight items are a given and remember you are responsible to determine if the airplane is airworthy for this flight.
    Let us know how it goes.
    Scott Sellers
  • Regarding item #3. Would be best to run the engine first, and check to make sure P leads are grounding. This is done by briefly turning the mag switch to off while the engine is at idle. If it keeps running then there's a broken P lead that should be repaired prior to doing your cold prop pull through in order to be safe. Mags must be grounding to safely pull the prop thru compression on each cylinder.
    Scott Sellers
  • I would point out this checklist, though I'm not saying it's better than what's above for this situation.
    https://cessnaowner.org/preflight-preparation-is-like-preparing-a-spaghetti-dinner/
    Digital Product Manager
    Cessna Owner Organization
  • @Scott Sherer @ScottS2459 @Rocky Landsverk
    Thank you all for so much great information!
    I did have a pre-buy completed which included a log book review and AD search. All came back clear and she’s coming with great documentation and all previous work has been done at reputable/certified shops. They did find a couple mechanical items, one of them being the Mags were past overhaul and the seller agreed to replace and not overhaul to get it done in a timely manner. In fact, the seller repaired/replaced all three minor mechanical items found, plus some cosmetics. The last annual was September ‘21 and it included the IFR re-cert. During pre-buy they changed the oil, cut the filter and sent it out for testing. Came back clean and I have the report. It does have a JPI engine monitor and I am familiar with the exact one in there since it’s the same as the one in the plane I currently rent.
    I will definitely do all of the things you are recommending and will let everyone know how it goes.
    Thank you again, this is all a massive help!
    Scott Nichols
    Wow, a meeting of the "Scott's". Way cool. Good luck with the new plane, Mr. Nichols, and post a few pics when you get her! :)
  • I’ll add one more suggestion. When I bought mine, I took a good friend who’s a CFI and a&p. He was also familiar with 182’s. Two heads is better than one. Also, we had a 3 plus hour ride home. It gave me 3 hours with a CFI. I had my complex, but not high performance. Got that. It was a very good first flight.
  • Two heads are better than one! Should have proofread!
  • Upload engine monitor data to savvy analysis.
  • Did you have a title search performed? If not you should. You don’t want to buy thousands of dollars worth of liens.
