Cessna Lubrication Guide?
I recently attended the Paul New cessna 182 maintenance seminar in tulsa ok. It was a fantastic, incredibly detailed seminar and I left with an incredible amount of new knowledge about my cessna. It was well worth attending.
One of the things stressed in the seminar was Proper LUBRICATION done regularly. Little did I know but during an annual inspection... LUBRICATION of anything is not required at all!. AND many things which should be lubricated regularly are never lubricated and the poor owner just assumes things are all being lubricated when the maintenance shop says" oh yeah we lubricate where needed"... well after attending the seminar... there is no way that is happening as there are 100's of lubricating points on a cessna and some of it is quite a lot of extra work. So i was wondering...
Does cessna publish a lubrication guide with time intervals and types of lubricants to be used on each part that needs lubrication? That would really help an owner keep track of everything. Proper lubrication really saves money so this could be a very well sought after guide by all owners if one exists?
John
    the standard 182 maint manual has checklists as well as lube charts. The checklist will be a good guide for time intervals. Carl
  • Where can one get or purchase one of these.
    Printed Cessna maintenance manuals are available from Textron. When you order your maintenance manual, you should also order its mate, the parts book.
    Hi Mike,
    Older manuals for older planes are available online at www.eflightmanuals.com for $50.00. They download in pdf form in moments.
    I would ask your mechanic or shop if they could print the lube pages for you. Its not like 40 pages, more like 5 or 6 max. What model do you have? Carl
    Here is a example of later model 182 lube chart. Its not rocket science ( well ok, it is) Pretty generic but you can get the idea of what gets lubed and when intervals. Carl
  • are there any recommendations for lubing the headliner zipper, so it won’t tear off when opening?
  • Not exactly sure what you mean but my inclination would be to try some kind of wax like car wax or even bees wax. It won't stain like oil will. Good luck.
    I go with Doug's idea of beeswax. Decades back on 747s we used to use a block of beeswax to lubricate all the zippers in the forward compartment on 747. Work well. Carl
    I knew I had bought some before. Do a quick Google search for zipper lubrication. There's lots of commercially available small quantities. Carl
