Parts and maintenance manuals
I recently purchased a 2008 T182T and as an A&P I need the parts and maintenance manuals. Textron seems difficult to maneuver through in order to purchase manuals. Anyone have some suggestions?
    There are many sources for manuals for your airplane including eBay. Just do a Google search with the model year and what you're looking for as a download or PDF and you're going to get pages of sources. Esco is a big source for digitized manuals and as I mentioned eBay actually has a pretty good selection too. Carl
  • Thank you. I’ll try EBay. What I can see, Essco doesn’t provide for the later models of Cessna 182s
  • Navigate here. You will need an account, but it's free.
    Then you can download the IPC.
    Switch to Tech Manual Search
    What I have found that when you get the paper manual, it comes with all the revisions. You could also use on line viewing, it's expensive, but the one year lets you get all the single engine manuals '96 on. Could be cheaper depending on your client base.
    Hope this helps.
    M, good sequencing, lots have trouble using the Textron site. Shame on them for making it a bit confusing. There is a lot of data as mentioned.
