Landing Light Change
I have C414. Want to change landing light but don’t know how to remove retaining ring. HELP! Need video or good description.
    Hi, I'll send this to our association A&P for an answer. Note: This is a holiday week and it may take longer to get you an answer. Please be patient.
    Here's the response from our A&P, Erich Rempert.
    There should be two little tabs on the snap ring like this, pull them together with a pair of pliers and the snap ring will pop out releasing the light.
    If the tabs are broken off (Many are) use a small flast blade screwdriver or a scribe (pick) to work one end out.
    The lamp will fall out once the ring is removed so be prepared!
